Replacement wall track advice
12’x24’, 52" wall
Purchased in 2006
Hampton
Looking for 8 round bottom rails, the one I removed is 5/8"x5/8" x 45 1/8" outside, couldn’t find that size on your parts page. Also need 1 side rail 5/8"x5/8" x 32" outside.
Would you recommend buying a longer size and cutting it down or might you have a resource to find manufacturer replacements?
Thank for your time.
Hi Frank,
Can you find any part #'s embossed into the underside of the pvc top caps that go between the top rails?
underside of the lower piece of the top cap (the upper piece has nothing) 04420002
Hi FranNV,
I did a little research and it does look like you have a Hampton Pool, this pool is made by Cornelius and we do not carry their parts. Here is a link to some Hampton Pool Documents which you may find helpful (parts listing, warranty & installation manual). I would suggest contacting Cornelius Pools directly and they may be able to send the parts out under warranty or sell them to you directly.
Let me know how things turn out.
Best of Luck!
