replacement top rails
I have a 18’ round Outback pool, it is about 15years old. I need replacement top rails .
Deminsions are 56 13/16’’ x 8 1/2 , would like to get rails that would be simular.I am not nesscessarly
looking to match up top cap for upright rails.Would like to keep price down, may replace pool a few years down the road. Would the seirra rail fit alright?
Thank you, Ray
Hi Ray,
Could you post a few photos of your pool to this thread.
  • One which is a wide shot of the pool showing the wall pattern
  • A close up shot of the top cap
  • A close up shot of the top rail
Also can you find any part #'s embossed into the top caps? All this information will help us find the correct top rails for you.
I need some replacement parts for my above ground pool. It is a riverview 24 52" I’m not sure the manufacturer maybe  artesian? I need to purchace 5 top rails and 4 caps. Can you help me find the part numbers for these on your web site?
Hello Citizen423 - We’d be glad to assist you. Could you post the following pictures?
  • Outside Pool Wall (Top to Bottom)
  • Top Rail
  • Top Cap
I have an 18 round ester williams summer dunes pool it is about 16 years old I am looking for replacement top rails which have started to rust could you direct me to the proper part number or rail that would fit my pool? The current rails measure approximately 54 1/2 inches on the front part of the rail with a slight curve (inside the pool) and 55 1/2 inches on the outside part of the rail.  There a total of 12 top rails and I will prob be needing 6. Thanks in advance Pat
Hello,
I have a 24’ x 48" Round Doughboy, Steel Frame, Blu Glacier Swimming Pool 21years “new”. This is a great pool. The liner and side panels are in great shape, however I do need to replace some of the top rails due to rust or corrosion. I won’t need  to replace the caps.
The top rail is considered “Super-wide, 8 1/2” Uni-fit Top Rail. What additional information would you need?
Would you please quote me on 4 Top Rails?
Kind Thanks,
Cara
Hello,
Kind Thanks,
Cara
Hello Cara - Unfortunately, we do not carry Doughboy parts. We recommend trying https://www.doughboypools.com/
I have a 27’ round Sea spray by Allure pool that need new top
rails, the pool is approximately 8-9 years old.
If your 27’ Allure has a total of 19 top rails, the replacement is part number 19922.
I have a 18x33 pool installed in 2007. It is salt water. The top stabilzer rails have rusted out. There are 4 different lengths of rail, 6x53", 4x37", 6x33", and then 8x8.5". All except the 8.5" ones are curved, the 33" ones just slightly. The 53" ones are the main round end ones, then the 37" ones in each “corner”, then the 33" ones along the sides. Would like to upgrade to resin if not too expensive, if not just get replacements.
Glen
If your 27’ Allure has a total of 19 top rails, the replacement is how to find and repair a leak in a swimming pool
I had such a problem. Thanks for the tip.
