I want to replace my Sta-Rite pool pump Model: Max-E-Pro P6E6-206L. Motor is Sta-Rite Model: K48L2PA105, 1HP, 1 Phase , 230V, 60Hz.
What is the best drop in direct fit replacement pump and motor (and its hp, service factor rating, and HP)?
What is the inlet height to the center line of the inlet/suction and discharge port s?
Please submit pump curve showing head/psi versus gpm flow rate and any variable speed rpm
