Replacement pump
I have a Hayward TriStar pool pump with a siezed motor. I am looking for a replacement motor.
From the label I see:
The model number is: SP3210Z1MR
The motor is an Emerson K63CXFEM-4993
1.5 MRHP,
Service factor 1.1
THP 1.65
3450 RPM
Volts 230/115
SF. Amps 7.7/15.4 PH 1 Duty Cont
60 Hz
Frame 56Y
I am very interested in the V-Green variable speed motor that has the controller with freeze guard built in. Would this be a drop in replacement for my motor? Could you provide links to the motor that I need? Also, a link to the kit that has all the seals that I will need for the motor swap?
Hi djplaistow,
Thanks for the detailed information on your motor that helps out quite a bit determining the correct motor for you. The direct repalcement for your pump would this Hayward Tristar SP3210Z1MR Motor
The V-Green 1.65 HP Variable Speed Motor would be a great option as a drop in replacement for your SP3210Z1MR you may also be eligible for a rebate from your power company, so you may want to check with them.
Either route you go we would suggest replacing your Hayward TriStar Shaft Seal
