Looking for a variable-speed replacement for Sta-Rite Max-E-Pro 1 1/2 HP Full Rate Energy Efficient - P6E6F207L
Hello Tom - If you are looking to replace the complete pump, we recommend the PureLine Prime model PL2606. This is a 2.7 total HP variable speed pool pump.
If you want to replace the motor, we recommend model ECM27SQU. This is a 2.7 total HP variable speed motor.
We recommend replacing the pump seals if you replace the motor. The seal kit for the Sta-Rite Max-E-Pro is part number GOKIT79.
