Replacement pool pump
I have a carvin century 2hp motor that is bad. Part number 7-184950-22. Can I order that same one from you guys or can I please have the replacement that would work? Thanks!
Here is the link to the correct 1.5 HP Full Rate Replacement for the 7-184950-22 Please note that the Total HP of the 1.5 HP Full Rate Motor is identical to the Total HP of your 2 HP Up Rate Motor, so the output HP is identical.
