Replacement Pool Motor Recommendation, Please
Hi - Would you please provide recommendations for the following pump?  Thanks very much!
Marathon 5KCR39SN2823AX
HP 1.5     V 115/230  HZ 60   PH 1
RPM  3450   Code K   SF 1.0
AMB  50C   Insul Class B
Time Rating CONT
Suitable for Field Wiring
1081 Pool Pump Motor
CAT NO C1319
Serial No  K11J230165
Used on a Hayward Pump Model# SP3010X15AZ;  Serial No  21110707050176014
Hello Steve,
The recommended replacement pool motor is the Motor 56j Thrd Up 1.5 Hp (b229se). I would also recommend changing out the seals on your pump with the Tune Up Kit Hayward Super II - GOKIT2 or the Saltwater Tune Up Kit Hayward Super 2 - GOKIT2SALT if you have a salt chlorination system. Thank you!
Inyo Alan
Thanks Alan.  I will place an order immediately.
I very much appreciate your quick and expert assistance!
Steve
You are welcome Steve! Thank you for your order and have a great day!!
Inyo Alan
