I need a new multi-port valve assembly and my book says it is a WVS003. But when I bring up your replacedment part it doesn’t look the same at all. Mine has two openingsn to attach hoses but your replacement part appears to only have one. Is this really the replacement?
Hi KeithDL,
Here is a Good Image of the WVS003 Valve. If you need to purchase this valve then you may do so through this link here WVS003 Valve
