Replacement motor
What is the replacement t motor for my Hayward A.O. Smith K48M2N111 motor. Can I just unscrew the old motor and screw in the new motor without changing the housing, plumbing, etc?Thanks,Mike.
Hi Mike,
The replacement motor for the Hayward A.O. Smith K48M2N111 motor is the UST1202 2 HP Replacement Motor Yes you would unbolt the old motor and impeller from your pump and then install the new motor on the pump. We have a Video on How to Replace a Pool Pump Motor which will walk you through the process.
Whenever you replace a motor on your pump we suggest a tune up kit, do you know which Hayward pump you have? The most common models this motor fits on is the Super Pump, Super II and Max Flo. Please post your model name back to this thread and we can suggest the appropriate tune up kit.
I want to buy your variable speed motor: ECM16SQU and I currently have Marathon 5kcr39un6190x with sta-rite pump filter.  Will your variable speed pump be an exact fit?
Hi cangm001,
Your Marathon 5kcr39un6190x has a true HP THP of 2.2 and the ECM16SQU has a THP of 1.65 so you would need to go up to the 2.7 Variable Speed Replacement Motor You may want to consider upgrading to a complete 2.4 THP Speck Variable Speed Pump which is about the same price as just the replacement motor. Please note that if you go with the 2.7 variable speed motor then you will only be getting the output of your current 2.2 THP impeller, so if you want to take advantage of the complete 2.7 THP then you would need to upgrade your impeller. To suggest the proper impeller we would need to know the make and model of your StaRite Pump.
I have a hayward k48m2n111. What’s the compatible  motor for this?
Hello Jag1985 - The replacement motor for model K48M2N111 is part number UST1202. This is a 2HP uprated motor with a 56J frame.
I replaced my old A O SMITH
CENTURION
TYPE CX FR  Y56Y
RPM  3450
VOLTAGE 115/230
AMP  SF  8.0/16.0
HP  1.0
CAPACITOR  30UF 2MEC9
with the
Raypak (Speck)
pump sn DET-0701300097
MOTOR MODEL PS165VSP.
Now my electrical usage went from $3.00 a day down to $0.85 a day. plus the $200 back from the power company.
Thanks for your advice.
HaroldB,
That is great to hear! We will let our friends over at Speck Pumps know that you are happy with their pump.
I have an Hayward Aqua Logic control system and need to replace my Eco Star Model Sp 3400 VSP. Can I choose between any manufacture and still controll the speed with my aqua logic controller. Please indicate all models that will work with my Aqua Logic Hayward controls. A/so if I upgrade to the newere Hayward pump will my old drive be interchangle with the new Hayward replacement  motor?
