Replacement motor -waterfall
I need to order a replacement motor for my Jandy MHPU 2.0 ProEdge pump. The current motor specs:
Century Centurion
PN: 10-193267-01
HP: TBD (2.0 uprate)
SF: TBD
Volts: 230/115
Amps: max 7.1/14.2
FR: P56Y
Form: KJM
type: CX
The pump is a Jandy MHPU model MHPU2.0
Hello Waterboy - The Century catalog number cross references to a 1HP uprated motor. The 2HP uprated sticker must have been slapped on there by a retailer. The replacement would be part number B2853.
We would recommend replacing the shaft seal when you replace the motor. The shaft seal is part number 35-423-1080. Use part number 5250-240 if you have salt water.
