I need a replacement motor for a Pentair challenger pump, 2 hp, full rated, 56y frame. What are my options and what is the recommended motor?
Hi Jeff,
If you have a Pentair challenger pump, 2 hp, full rated, 56y frame then you will need this 2HP Full Rated Pentair Challenger Replacement Motor when replacing your motor we strongly recommend a Pentair Challenger Tune Up Kit this will ensure you don’t have any leakage when you replace your motor as this kit comes with a new shaft seal and all the o-rings and gaskets needed for the motor replacement. We also have a Video on How to Replace a Pool Motor which you may find helpful when you perform your replacement.
Thanks so much
Thank you Patrick for the quick response
You’re welcome Jeff if you need any help please let us know.
Will do. I just placed my order!
Thanks Jeff, that’s great!
