I have an old Ikeric VS pump and I am looking to just put a new single speed motor to replace it since the electronics are shot on the Ikeric system. Will the AO SQ1152 do the job? Model # on the Ikeric is a Sta-Rite p48m2eb7 on the motor.
The direct replacement motor for your P48M2EB7 is model Q3152. You currently have a 3-phase motor.
The SQ1152 is a single phase motor. However, the SQ1152 has the same frame type and shaft size. It should mount up to your existing pump housing.
