I have the Hayward Spuper Pump II Model SP3010X15AZ. It has the 2 inch pipe connections. I want to replace my motor with a variable speed motor. Can you recommend a replacement motor
The replacement variable speed motor would be model ECM16CU.
We’d also recommend replacing the seals when you replace the motor. The seal kit is part number GOKIT2.
