Hello - I have the Century 7-193990-07 motor on a Jandy SHPM2.0-2 pump. It is making a loud squealing noise so I believe the bearings need replacing. Is this an easy fix or should I replace the motor? Which is the correct motor to buy from you guys?
Thank you
Thank you for contacting Inyo. If you are a handy person, the motor bearings can be replaced. However, most homeowners prefer to replace the complete motor.
Your motor would require two 203 bearings.
Model B2983 would be the complete motor. This is a full rated 1.5HP 2-speed motor but the total HP rating is 2.21.
Model B2983 will be the best one.
