Replacement for waterway svl56
Hello. I am looking to replace a 2 speed waterway svl 56 2 hp pump on my swim spa. I have three pumps. This will be for the main pump. I am interested in the pure line pumps. What would be the best pump for my application and how will it compare with what I have now? Thanks for your time
Hello AnthonyB - We’d be glad to assist you. The PureLine Prime is the most durable pump in the PureLine series. We would recommend the PureLine Prime model PL2606. This is a 2.7HP variable speed. It’s the most energy efficient option available.
Thanks for your response. I already have a spa controller with a heater controlling the three pumps. Is the variable speed pump really necessary for my application?
If you were looking for a pump specifically to run on high speed, I’d say it would not be necessary. Since this is the main pump, the ability to switch the speeds depending on the needs would be appealing. Running it on the low speed of a variable speed pump is going to be more energy efficient than a 2-speed model.
