Replacement for colorlogic 4.0 12v led
I have 2 colorlogic 4.0 pool lights and both have malfunctioned and will not stop flashing,  hayward says it is a bad board and the lights need to be replaced.  I have maybe 50 hours on them, but past the warranty. I’m not much of a night swimmer.  My question is what can be put in their place so that the bulbs can be changed out easily if they go out.  I believe the niche is sp0607u for vinyl inground pools.  I would like a system that can unscrewed from the housing, take out the fixture, open it change the bulb and put it back.  I would like to know your recommendation on what I should get that will fit the niche and the order numbers of what I need to change them out.  I have a 12 v LED colorlogic 4.0.  Or if there is something better that I can do, would you let me know? Thank you.
