Hi Opey1018,
Could you post a few more photos of your pool to this thread.
- One which is a wide shot of the pool showing the wall pattern
- A close up shot of the top cap
- A close up shot of the top plate
- A close up shot of the top rail
Also, can you find any part #'s embossed into the pvc top caps and metal top? Many times the part # is on the underside of the top cap. All this information will help us find the correct replacement parts for you.
We have sent your pool wall image off to our manufacturer to see if they recognize the pool wall pattern, if so then they normally can suggest the appropriate parts based off of the wall pattern. We will be back in touch.
Hi Opey1018,
We heard back from the manufacturer and they need a close up image of the top cap, also can you look underneath the top cap to see if you can get a part #? This is the information need to try and identify your bottom rail
