I purchased a B842 motor from you in March of 2014 and recently the front bearing has started making noise. I disassembled the pump down to just the motor to confirm it was the bearing. Before tearing the motor apart, I’d like to have the bearings so I can take it appart and repair it in the same day. It is currently working but noisey so I can run it until parts arrive. Can you tell me what bearings I should order for front and rear of this motor.
Hi KBradley,
I’m sorry to hear about your bearings. You will require two of these 203 Pool Motor Bearings We also have a Video On How to Replace Pool Motor Bearings which you may find helpful.
