? Can replace a hayward st1102 1hp with a super flow motor?
Hello Heathcliffe45 - We’d be glad to assist you. As long as the frame and total Hp are the same, you can use that motor. Your motor frame is 56J and your total HP is 1.5. You can calculate total HP by multiplying the HP and Service Factor (1HP x 1.5 SF).
If you are referring to a Pentair Superflo motor, that will not work because those motors have a 56Y frame.
