Replaced Hayward sand filter valve with new valve same part number but every position doesn’t seem to work properly like they aren’t lining up on regular flow it’s seems like it’s not going through the sand and back wash comes out real slow and can’t see it moving in the glass of the filter valve.
Replaced the valve with a new one same part number took out in one place so I put the valve in the same position, but seems like a all the positions I put it in they run very slow like the backwash position water comes out slow except the regular position it cbcomes.out with 9 lbs of pressure to the pool. All lines are in the right position too from pool to pump and filter to pool. Can’t figure what’s wrong
Hi Camarotj1,
Could you post a few photos of the area in question?
