Greetings
I have replaced the bearings and the shaft seal myself. rotor/impellor spins with no issue
when I apply power motor just hums.
Is the start capacitor bad? If so can you tell me which one I need, The writing on
capacitor is gone.
motor manufacturer: AO Smith Century Centurion pool pump
Part #: 7 - 187630-02
s/n: 015073M
Type: CX
Hello Psandova - Below are the instructions for testing the capacitor.
Capacitor Check (Start or Run)
• Set ohmmeter at Rx 1K.
• Slip a heavy piece of paper between points on the switch.
• Discharge capacitor by touching the two terminals simultaneously with the blade of an insulated handle screwdriver
• Attach one probe to each terminal. Ohmmeter needle should move rapidly to right then slowly drift to the left. (Low ohm reading to high ohm reading.)
• If digital meter is used, readings should start low and rapidly increase to maximum value.
• Replace capacitor if bad
Your motor only has a run capacitor. The run capacitor for your motor is 370v 30mfd. The part number is 5VR0303.
