Currently have a Centurion 0-164302-24 HP 3/4SF 1.50 volts 230/115. S56J. The bearings are shot. I need to know if I can replace it with an AO SMITH UCT 1072? Do I need a tune up kit or does it come with new gaskets?
Hello Angela28451 - The UCT1072 would not be the correct replacement because it has a lower service factor. You would require a 3/4HP motor with a service factor of 1.5 or higher. The energy efficient version of your 0-164302-24 (B127) is model B638.
The motor does not come with seals. The correct seals will depend on the make and model of the pump. What is the make and model of your pump?
