Replace pool and spa lights with LED color changing
I need to replace both the pool and spa light bulbs.  I would like to go color changing led’s if possible.
Pool light: American Products 400 BCL, 120 volts, 400 watts, R-40
Spa light: American Products 7810xx, 120 volts, 100 watts, R-20
Need a recommendation on both pool and spa lights and gaskets and anticipated deliver time.
Hi MrJimbo,
I would suggest this PureLine PureColors 120V LED Pool Bulb and this PureLine PureColors 120V LED Spa Bulb these have been great LED color changing bulbs at a very good price. You would also require the Pentair Amerlite Lens Gasket and the Pentair Spa Brite Lens Gasket. The 120V Pool LED bulb was a very hot seller this year so it is currently on backorder, our shipment of this bulb is due in on July 15th and would be estimated to ship out to you on July 15th if you placed an order.
