Remove SPX3010-C impeller
How do I secure the motor’s shaft to unscrew the Impeller.  Pump is Model SP-LE-40014
Hi Tony
You will take off the motor end cap and put a flat box wrench on the end of the motor shaft this will secure the motore shaft so it cannot spin, you then go to the impeller to unscrew the impeller off of the shaft of the motor.
About at the 2:45 minute of This Video it Shows How to Remove a Pool Pump Impeller let us know if you have any questions after to watch it.
This was the best response possible. Thank You
Thanks Tony I’m glad that helped!
