So…is this fixable without a replacement? Water is dripping off the top of that metal part and dripping pretty solid…pool heater not running but water flows through I think just when pool pump is running.
Is the leak at the pressure relief valve? You may need to replace it. I’m not sure those are repairable.
Check out our complete offering of pool parts.
Even if you fix it, it won’t last long, over the years it still leaks
