I purchased a home that came with a pool in need of love. It is a 16x32 doughboy above ground pool. I am replacing the liner, filter, and pump. I have an issue where the side rail is missing and they built a deck over that side rail using wood to hold down the liner recreating the rail under the deck board. While i can deconstruct the deck and reconstruct it using the wood to recreate the top rail I would prefer to do it correctly and put new top rails on the pool. Can you tell me where I can find compatible top rails for it?
You can contact Doughboy directly and see if there is a Doughboy dealer in your area. That is the only way to get parts directly from Doughboy. https://www.doughboypools.com/
Another option is to contact LoMart. Lomart and Doughboy are made by the same manufacturer and the parts are often the same. https://lomart.com/pools/
