Hi, new to the aboveground liner pool, what type of cleaners are best for liner pools? Is there a method whereby the cleaner does not suck up the liner? or is that a risk or concern?
Hi GailAPW,
For flat bottom above ground pools my favorite is the Pool Rover Junior Robotic Pool Cleaner I like this cleaner because it runs independently from your pool pump. The benefit of running independent from your pump is that it costs much less to operate, also many times pumps can be underpowered to operate a pool cleaner. The Pool Rover Junior is designed not to suck up the liner.
Great thank you!
