Hello,
I have a Jandy WPHV500WP100 fixture. The incandescent bulb burned out and I purchased a replacement LED Bulb:
Life-Bulb Color LED Pool Lights… Amazon.com
The bulb works, but as soon as I move the fixture the bulb falls out of the socket. When I’m screwing in the bulb it feels a little loose. Any ideas?
Thank you!
Chris
Hi Chris, it sounds like the bulb does not have an E26 base installed on it. Different countries use different bases, so check to make sure that the top of the metal lamp base is 1" in diameter and 1" in length from the top of the metal bulb base to the bottom. If it is smaller then it won’t stay in the socket.
PS We have this Pureline LED Pool Light Bulb Color Changing 120V 35W - PL5889 that is slightly less watts (35 watts) for about half of that price.
