Can the Jandy Aqualink Touch be used to control the Pureline Prime pump or will the User Interface on the pump itself need to be used to set pump speed and runtimes?
Good Day MNorman. The Jandy AquaLink Touch cannot be used to control the PureLine Prine Variable Speed Pumps. The pumps interface is what you will use. The V-Green Automation Adapter Kit - 2517501-001 will be required if you would like to set different speeds for specific application or features.
