Hello JoeKellar - We see that you started a new thread but unfortunately there was no question. What can we help you with today?
i have a 33,000 gal.in door pool i have a hayward sand filter pro series i would like to add a good cartrige filter and a new moter my filter is 16 years old the hayward pump 5yearsold should i use them both or go with new pump and filter what woould you reccomend,and cost thanks for your time joe.
We’d be glad to make a couple recommendations. Based on your pool volume, we recommend the Hayward C1750 cartridge filter. If this is a commercial pool or a pool with a heavy bather load, you may want to go with the Hayward C3030 quad cartridge filter.
For the pump, we recommend the PureLine Prime 2.7HP Variable Speed Pump. The variable speed pump is the most energy efficient option available.
As far as replacing the pump or motor, check out our article titled “Pump or Motor: To Replace or Not to Replace…That Is the Question”.
