Can this pump be wired for 230V?
Hi @will52 unfortunately the motor listed in your photo can only be wired 115V. Is this being used on an inground pool or an above ground pool? If it is being used on an inground pool then you might consider the PureLine Pure Flow Pump 1.5 HP 115V/230V which can be wired either 115V or 230V. Why are you needing to wire 230V?
Above ground 80 feet of wire to box and only Z-wave controller I see to support 20 amp motor is the:
Aeon Labs ZW078-A,White,V3.26,US,AL001 Zw078-A Z-Wave Heavy Duty Smart Energy Appliance Switch
It looks like the Intermatic CA3750 Z-Wave can take 115V.
show out of stock everywhere. Order pending from amazon
wiring question for the B2983 I purchased from you. I also bought a toggle switch with no wiring instructions. I have two black and a green from power source. I know the green is the gound but the two black wires is the question. do I cap one black wire and nut together the other black to the black/yellow of the toggle switch?
