Pump Wiring Issue
I am replacing my Hayward dual speed pump with a Xtremepower dual speed. On the Hayward, there are four wires (Red, Black, Blue, and Green). On the new pump, there is a switch to change speeds from low to high. The wiring of the new pump has only two connections and a ground. The Hayward has three wiring connections. Am I able to wire the new pump to have my controller change the speeds instead of using the switch on the pump? If So, how do I wire that? If it is not possible, how do I wire the new pump with only two terminals?
Those are good questions. Can you post pictures of the wiring diagram for the old motor and the new motor on the new pump (it is generally printed on a label on the motor)? Is the new pump designed for 220 volts or 115 volts? And what are you using as a controller?
