Need to upgrade to VS pump. On a budget. Current pump in photo. Also want to add inline chlorination.
You could upgrade the motor and keep the existing pump end. The variable speed motor would be model ECM16SQU. The ECM16SQU is a 1.65HP motor that will hook right up to your Whisperflo pump.
We’d recommend replacing the seals if you replace the motor. The seal kit is GOKIT32.
Are you looking for an inline tablet feeder or a salt system?
Is there a PureLine vs pump that would be equivalent? I’m redoing all valves and PVC.
Tablet chlorination.
I would recommend the PureLine Prime model PL2605. This is the most durable 1.65HP variable speed pump in our line up.
As far as the inline tablet feeder, we’d recommend the Rainbow 320 model R171096.
