Pump terminal cover
Hello,
The terminal cover on my pump motor is cracked in half but I can’t seem to find a replacement.  The motor is a Century Centurion USN1152 replacement for the Haywood Northstar Pump.  HP. 1.5  SF 125  FR N56J  PArt 7-192685-02
I just need to the back cover that screws in that covers the wiring, etc…  It has 2 screws that connect it to the motor but I can’t find it.
Thanks,
Greg
Hello Gregory - The back cover for the USN1152 is not something we carry. I’ll check with our Century rep and see if this part is available.
Good news. We can special order the back cover for your USN1152. The part number is 18906802. It may take a couple weeks for delivery because the cover by itself does not meet the minimum order requirement by Century. We’ll have to send over a larger order. This will delay the delivery to you.
Thanks.  $32 is a little more than I am willign to spend on it.  I will check some local places to see if someone can pull one off a broken motor.
Thanks,
Greg
You’re welcome. Good Luck!
