Need to replace a failing pump. Mfg. says the correct pump is a AE100FHL. THe pump p/n is K48M2PA105C3. Which pump and kit do I need to replace this item.
Hi Zonafied,
You would need the SQ1152 1.5 HP Full Rated Replacement Motor for your pump. When replacing your motor you will also want to get a Max E Pro Tune Up Kit typically if you use your old shaft seal it will not mate up properly and you can damage the motor (damage due to a leaking shaft seal is not covered under the manufacturers warranty). We also have a Video on How to Replace Pool Pump Motor which you may find helpful.
