I need to replace my Century Centurion pump motor. It is attached to my WhisperFlo pool pump. I didn’t find the exact replacement part on your website. Could you confirm that this pump will work as a replacement?
Your website: Century 3/4 HP Square Flange 56Y Full Rate Motor - B2847V1
My pump: Part #8 - 177449-033/4 HP
Serial BX7-015
Looks like the RPM, Voltage, and Amps are the same.
Thank you for your time,
Brian Evers
