Bought a replacement motor when our pump motor seized. However, everything is so corroded that I cannot remove the old motor from the front of the pump face (I don’t know the name of this part, it is where the impeller connected to the pump) I was able to remove the impeller no problem. I actually don’t even know if the motor can be removed, and I don’t know what the name of this pump is. (all stickers, or what is left of them, have fallen off or are so weathered they can’t be read).
I would even consider purchasing a replacement piece for this pump part. I was hoping to be able to replace only the motor and not the entire pump, as that still works fine and I prefer not having to cut pipes.
Any help is appreciated…see pictures below.
