Pump Motor Replacement
I have a motor on my pump that just went out. The Model number on the motor is UST1102. How do I tell if the model I have is flanged or not? Trying to order a replacement motor, but not sure which to order.
Hi BruceW,
If your motor says it is a UST1102 then this is a round flange motor and you may view or purchase the UST1102 Replacement Motor here. When replacing your motor we suggest replacing your shaft seal, do you know which pump you have? The most common pump that the UST1102 goes onto is the Hayward Super Pump and if you have this pump then you will require a Hayward Super Pump Shaft Seal.
We also have a Video on How to Replace a Pool Motor which you may find helpful.
