Hello. Do you carry the 2 water slingers and flat washer for the motor in the picture attached? Thank you.
The water slinger is part number 5056-04.
Which washer are you referring to? Is it a washer for one of the bolts that secure the motor to the pump housing? If so, what is the make and model of the pump side?
Sorry, the metal washer that sits between the water slinger and the outer rubber washer. It is pressed in. Also, do you have a number for that outer rubber washer? Thank you.
If you let me know the make and model of the pump, I can find those parts.
