I would like to rebuild my motor. Is there a reseal kit with replacement bearing available?If not, do I need 6203 or 6201 bearings?
Eek, thought the tag would show the model.SP 1580 Z2
Hi Urtoo33,
Unfortunately the Power Flo LX has used both the 6203 and 6201 bearings, you could by a set of both and return the ones that were not needed. Or if you want to remove the old bearings and measure those we then could let you know if you need the 6203 or 6201 bearings.
Thanks for the reply Patrick, looks like I need to buy both sizes, as this is a running pump. Do you carry these and the gasket rebuild for it? Is this a 1500 series rebuild kit pump?
We do carry the 6203 Bearing and yes you would need this 1500 Series Hayward Tune Up Kit. Unfortunately, we do not carry the 6201 bearing.
Hi, I have a V-Green 1.65HP ECM16CU variable speed motor that is starting to get noisy. Do you carry replacement motor bearings that fit this model? The increased noise just started two months after the 18 month warranty ended ![]()
Thank you,
Eric
