AO Smith 3/4 hp motor QC10072 for pool sweep needs gasket.
Pump is Anthony with part number very worn but appears to be AJ104-21. Serial number completely unreadable. Is this enought information to get proper gasket?
Thanks, Jerry
Thanks, Jerry
Jerry, there happens to be a few important seals and gaskets for your series booster pump. Please click here to be directed to that parts diagram so you can select the parts that you need. https://www.inyopools.com/parts_anthony_aj_pump_parts.aspx
Thank you Anthony. If you can assure me these parts will work with my AJ104-21 for fresh water pool, I have them in my basket and will place order:
Gasket 3299-01
Seal 5250-100
Slinger 5056-04
Appreciate your help. Jerry
Jerry, yes those parts are indeed compatible with your model AJ104-21 Anthony booster pump.
Gasket 3299-01
Seal 5250-100
Slinger 5056-04
Hector, thanks, i just placed order. Jerry
