Thanks,
Harry
Thanks,
Harry
Hi, Unfortunately since unions were not installed then you will need to cut the plumbing. When re-plumbing I would suggest quick-disconnect unions. I can’t tell if you have a Polaris Booster Pump or a Pentair Letro Booster Pump so I will provide the appropriate unions for both Booster Pumps. FYI installation of the unions will require you to change the plumbing from hard plumbing to the soft hose which is included in the Kits.
Thanks Patrick!
I have a Letro Legend booster. Does that change anything?
Harry
Hi Harry,
That is good you will need these Letro Legend Unions and you can use your current hard pipe plumbing (i.e. don’t need to replace with hose).
What’s the part for the housing itself?
Actually I think I was mistaken on my last comment. It looks like you will need to replace the hard plumbing with hose and you will require the Letro Legend Union Kit with Hose instead of the last item I suggested.
Hi Harry,
That is good you will need these Letro Legend Unions Tellpizzahut and you can use your current hard pipe plumbing (i.e. don’t need to replace with hose).
Thank you for sharing your knowledge.
Thanks InnocentFox!
