Pump Conversion
I’m converting from a two pump system to possible a single variable speed pump system. How to I feed the pool sweep without the 3/4hp booster pump? (Main pump is 1.5hp)
Hello GreggM - We would not recommend eliminating the booster pump unless you are switching to a cleaner that does not require one. Booster pumps are designed to provide high pressure with low flow. This is the opposite of a standard pool pump.
If you want to eliminate the booster pump and only use your pool pump, we recommend the Polaris 360 or The Pool Cleaner 4-Wheel Pressure model. These pressure cleaners would plug into a standard return fitting.
