Hello,
The water in my Pentair Variable Speed Intelliflo pump basket is 3-4 inches below being full. I changed the filters, cleaned the basket and lubed the O-rings for the basket and filter and filled the basket with water.
I checked the basket about 15 minutes after turning everything back on and the water was about an inch or two low so I turned everything off. The next day the water level was the same as when I turned the pump off the night before. I assume that I have a leak and air in the system somewhere?
The pump was installed in 2015. I’m wondering if the GOkit or lid kit might solve the problem, but sure if I should look at something else. On Inyopools.com, I selected "Intelliflo VS / SVRS (Pre-June 2016) link and it takes me to a page to order parts, but the parts listed are for the Whisperflo are the correct parts, much less the parts I need to fix the problem.
Thank you,
Sean
