Hi - I took out my pool pump It is a Magnetek part 8-165119-04. I have the impellers attached and I need that for pulling the water into the tank. I would like to purchase a new motor, but know I need those impellers to process the water into tank. Do you have any recommendations? I can’t seem to find that part anywhere.
Hi TomasGarcia,
Normally you should be able to remove the impeller off of your old motor and use it on the new motor. Here is a Video on How to Remove a Pool Pump Impeller which you should find helpful. Here is the 8-165119-04 1 HP Keyed Shaft Motor you will require.
