Pump and filter replacement
Hello, I just purchased a home with an older unground pool. 16x32 with a 13ft deep end. The pump and filter are in desperate need for replacement. The current filter is the sta rite t200bp1 which is no longer available anymore. Question is, what filter is nearly identical as far as size and port size/port location. And what size pump should I look at based on the size of pool and that’ll work well with the filter? As economical as possible. Thank you
Based on your pool size and previous filter, we’d recommend the Pentair Sand Dollar SD-60. The SD-60 is a 250 pound 22-1/2" sand filter.
The pump we’d recommend is the PureLine Prime model PL2605. The PL2605 is a 1.65 variable speed pump.
