I have a Clear Bay 48-Frame Pump, 1.5hp. What rebuild kit do I need for the pump, motor is fine. Reason for needing the rebuild is that the pump lost prime due to leaves clogging the skimmer.
Assuming it is the Waterway Clear Bay Pump, the parts can be found on the following page. http://www.inyopools.com/parts_waterway_hi_flo_above_ground_pump.aspx
