I have an older pull pump system and it seems the motor bearing have gone bad. I have an couple of questions on what is the most economical and logical route it take for the fix.
- Buy a new motor and impeller system to fit the current pump
Motor:
Part# 10-158367-04
Cat# B106
Impeller Pump system
Brand: PUREX
Part# is worn off (see photo’s)
On the impeller the set screw is rusted on. I might be able to use heat to remove, but it may strip out. Is it worth going through the process?
- Do I purchase a entire new pump system that fits my current set up? If this is an option what is the most cost effective way to do this?
See attached photo’s
Look forward to hearing your response need to get up and running ASAP, but don’t have a ton of money to spend.
Thank you for your time,
Joshua Cook
