I have a Proline Above Ground pool pump SK P711-15H, Model PE71-II-H and need a new motor (currently an AO Smith Mod S48AA48D29. Need new motor. Which one do you have that will be a bolt in replacement? Thanks
Thanks masinstr for the post… for the SK P711-15H, Model PE71-II-H ProLine pump you will require the BN25 1 HP Replacement Motor and you would also need an E71 Shaft Seal If you have any questions please let us know.
From Masinstr
Do you have a 1.5HP motor? That is what is currently on the filter. Thanks
Yes here is the BN35 1.5 HP Motor for the PE71 this motor should do the trick!
