Programming Pentair Pool Pump
I need to reprogram my Pentair Pool Pump and need to know how long to run it and what speeds to run it. Can you help me, please.
Terry
Hello Terry - Thank you for contacting Inyo. Unfortunately, there is not a universal answer for your question. Every pool system is different and there is not a standard speed setting and run time. The goal is to turn the body of water over once a day.
I would recommend adding a pool flowmeter to your plumbing. This way you know how many gallons per minute are being produced at each speed. Then you can easily determine how to program the pump.
